Budget (including currency): $1
Country: Canada
Games, programs or workloads that it will be used for: Games, mainly open world single player games.
I'm in the process of building a new computer and would like a CPU recommendation. I have the following parts currently. PCIE Gen 4 KC3000 Kensington 2tb SSD. 3060ti, 1080p monitor 165hz G271C, 8 tb Seagate HDD, GIGABYTE X570S AORUS ELITE AX AMD X570 DDR4 Wi-Fi 6E Bluetooth PCIe 4.0 M.2 USB 3.2 ATX Motherboard, 32GB 3200 CL16 memory, DVD-RW. I have no intentions of changing anything in my system. I am happy gaming at 1080p. What I want is a computer that can still perform decently 7 years from now. I know in a few years I will need a GPU replacement to keep the system fresh. The games I play are things like Elden ring, Dragons Dogma, Dark Souls. I only play single player games. My options are 5800x, 5800x3d, 5900x.
Thanks for your time.
https://linustechtips.com/topic/1464666-need-a-cpu-recommendation/
5800X for best bang for the buck IMO... I have a 5900X and it admittedly is overkill. However, food for thought, that might not always be so. The 3D might be nice to have in the future as more games begin to take advantage of it, though.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Do you think the 5800x offers good longevity? Or will I be better off with one of the othe CPU's
I presume by longevity, you mean that you want to avoid any major upgrades or replacement for at least a few years, and yes, I think it would from that standpoint.  But be mindful that Ryzen and their supporting boards are fussy about RAM, so check the board manufacturer's QVL list for the specific RAM kits that have been tested and known to run stable on that particular board and processor combo. RAM instability is a thing with Ryzen, and it can drive you nuts if you pick the wrong kit.
Yes my intentions are to keep this PC for as long as possible with the only change being a newer GPU in a few years. Thank you for your insight.
Country: Canada
Nothing you can slot in an AM4 board is going to last 7 years. By then we will be on 24 core Ryzen 5's and Intel I5s that boost to 7+ ghz for $300-400. Have fun rocking your 5900x when that happens. We are in the golden age of cpu advancement with the competition from AMD and Intel. There is no such thing as future proofing currently.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Of course you won't be able to have the same experience that you do now but that doesn't mean that you can't have a decent experience in 7 years. My 7 year old laptop still offers a decent gaming experience.
24 minutes ago, FAQCYA said:
With just a $30 difference I would rather get a 5800x it will have more usability in the future.
How so ? It is basically the same cpu with just a slightly lower clock speed. There is only about a 1% - 2% max difference, so nothing that you are going to notice.
I thought there was a bigger difference then that. If the difference is that small then it wouldn't be worth the extra 10% cost.
You will get the best longevity and performance out of the 5800x3D. It’s what I’d buy. The 5700x is also a very good choice for cheap, overclock it a tiny bit and it will beat the 5800x
For single player games you will want at least a decent-sized (27”-32”) 1440p monitor, btw, and you could even go 4K. 1080p is better in competitive shooters and stuff where every frame counts, although I still prefer 1440p large monitors (32”) in those.
Yeah the difference isn't much at all.
The review below is with an RTX 3080. The 5800X and 5800X3D are also shown. With a 3060 ti the gap will be even less.
https://www.techpowerup.com/review/amd-ryzen-7-5700x/15.html
Your larger issue is that neither the 5700x or 5800s are going to have 7 years of longevity. For that long of longevity you really want Zen 4/AM5 and even that is a massive stretch
