if i purchase two packages of single 1x16 gb ram and put them in the same system will it work? if so will there be a performance decrease?
Solved by WoodenMarker,
If the ram is the same model, it should work just fine.
By default, they should run at standard jedec speeds dictated by the motherboard. If one dimm is slower than the other, you can run the sticks at the slower speed of the two.
Featured Topics
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News0 -
2
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
8
