Budget (including currency): preferably less than US $800, My absolute max is US $1000
Country: United States of America
Games, programs or workloads that it will be used for: Games: Elden Ring similar games
I am wondering if you guys have any recommendations for my build or tweaks I could make to my existing build (not in real life, in pc part picker). I don't know if it is worth it to do zen 4 or zen 3. Here is the link to my build https://pcpartpicker.com/list/v9t9v3. Or also refer to the picture I attached.
https://linustechtips.com/topic/1463909-first-pc/
This youtube video showcases games and their framerates played on Ryzen 5 5500 and RX 6600 system, (with slightly faster RAM and better Motherboard, but that doesn't really change much).
Elden Ring at 3:28 locked at 60 fps (probably Vsync or something)
This basicaly shows you how rough estimate of how the parts you picked would have performed in games showcased on those specific quality settings.
  • Looks fine to me
  • idk if better than stock CPU cooler is needed but nothing wrong with keeping things cool
  • I recommend heading into PSU section on this forum and asking of the PSU is good enough for this build
current PC:
PC configs I used before:
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627696
Good build but id use a 5 pack or p12 or p14 arctic fans, really good for the price and not far off from the noctua a12x25
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627702
If you have Case fans included in your case then dont buy the noctua fans and stick with the default case fans. Why? Because they are expensive, your pc isn't getting hot enough for it to matter and now you saved money for a better cpu. In conclusion my only tweak would be the cpu ( the ryzen 5600 or 5600x is a pretty good cpu)
Your psu should also be enough for this build. I have a friend with the same gpu and almost identical cpu
With a 500watt psu and it works splendidly.
But dont take my word for it and ask around. Im just trying to give you my perspective and as a human with common sense you should see what other pc fanatics think of you build.
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627707
6 minutes ago, Milka_1 said:
If you have Case fans included in your case then dont buy the noctua fans and stick with the default case fans. Why? Because they are expensive and now you saved money for a better cpu. In conclusion my only tweak would be the cpu ( the ryzen 5600 or 5600x is a pretty good cpu)
isn't 5600 and 5600x the same CPU but very slightly faster/slower?
current PC:
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627717
https://pcpartpicker.com/list/kHzC9r
Damn i just have a list from a previous thread laying around that happens to be perfect for this thread, its even <800$
Yes buy a used gpu, 6800 float around ~400$ on ebay, far far superior to a 6600
Also case has 3 fans already so no need to buy more
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627718
1 minute ago, Milka_1 said:
You are absolutly right! In this case it would not matter and i would opt to go for the non x version for the lower price.
Unless OP is planning to play/do something more CPU than GPU reliant, which "gaming" doesn't sound like that's the case
current PC:
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627726
Exactly. For "future proofing" you might want the x variant but personally i think it doesnt matter. He is just playing gpu bound games and not cpu bound games so it should be fine. Even if its cpu bound i think the ryzen 5 5600 can handle it. But some simulators and building games might get rough on high/ultra settings.
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627747
Too much money in useless cooling, drop the cooler and fan, instead get a 5600 and a nvme drive, maybe a b550 board as well
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627779
3 minutes ago, Delver said:
here is a revised version of the build because of your guys comments, what do you think?
I'd look for a better PSU, 500W is barely enough and those VS units are pretty mediocre.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627793
Eh my list is likely still better especially psu wise, you are getting a shittier lower power unit heck its underpowered yet its only 7£ less than a 650w legion gx pro and thats a solid psu
If you want a better ssd then get a cs2030 or equivalent, 1030 is just another lowend ssd
5500 vs 5600 not that much diff in performance, id just save the 40$
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627799
I just realized that I would like to play some city sims/builders, would you still recommend a 5 5600?
https://linustechtips.com/topic/1463909-first-pc/#findComment-15627856
It's really no fun buying a semi-modular power supply. Also like @Pixelfie said, you really want like 750-850watts these days
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1463909-first-pc/#findComment-15628056
Eh id still go 5500, performance gap can be closed by ocing to 4.6-4.8g 1.3-1.4v static allcore
you can also increase performance by ocing the balls off the ram till you hit max ram speed on 1:1 ram : fclk so around 5000mhz cause its cezanne but that is just p a i n because high freq ram oc though youd see larger gains than on other chips due to the 5500 having smaller cache
https://linustechtips.com/topic/1463909-first-pc/#findComment-15628228
