Does NZXT Internal USB Hub 3 fit in back of case?
Solved by BlueChinchillaEatingDorito,
22 minutes ago, HungryHamster said:I was just wondering if the NZXT Internal USB Hub 3 fits in the back of the case where the cables go or if it only is something that fits in the front of the case where it can be seen. Does anyone know?
It'll ultimately depend on your case. Common placements would be the PSU basement or in your drive bays. It won't really fit in the behind the motherboard tray because you'll them be pinching the USB header cables a lot. There's just not enough clearance for that in most cases.
