I just installed a new H100i in my case yesterday, replacing my 212 Hyper Evo. I wanted to try for a bit of a better overclock on my i7 3770k. I took note of my previous temperatures, 32 at idle and around 50 while gaming, to compare to my new temps. I am now idling around 40 degrees and getting 55 at load with the H100i, having yet to increase the overclock. My question is, what could be causing this increase in temperature with the new, better H100i? I applied my thermal compound appropriately to the CPU, and had no problems with installation, but I can't seem to think of why my temperatures would be so much higher than my previous cooler. Any chance that it is just a bad cooler?
https://linustechtips.com/topic/146340-heat-problems-with-h100i/
hmm... 40 at idle isn't good, but it also depends on what speed are you overclocking your cpu.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1954256
My h100i keeps my 4670k @4.4 @1.1V around 35 at idle and like 50 on load. I'm not much help in telling if you have a bad cooler but am trying to give you an idea of what temps might/should be.
Edit: there are sp120s on the rad if that makes any difference
i5-4670k, Asus VI Hero, Corsair Vengeance Pro Series Red 8GB (2x4GB) @1866 MHZ, EVGA GEFORCE 780 FTW w/ACX Cooler, Fractal Define R4 Windowed (Black-Pearl), Samsung Evo 250GB, WD 1tb Blue, EVGA SuperNOVA NEX 650, Acer H236HL 23" x2, Corsair H100i, 2x Noctua NF-S12A, 2x Noctua NF-A14, Steelseries Apex, Logitech G602
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1954288
My h100i keeps my 4670k @4.4 @1.1V around 35 at idle and like 50 on load. I'm not much help in telling if you have a bad cooler but am trying to give you an idea of what temps might/should be. Edit: there are sp120s on the rad if that makes any difference
thats bcoz thats a really good chip giving 4.4 at 1.1v... :)
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1954301
I have a Kraken x60 and my idle temps are 28C and 50ish under a load but i have a small overclock
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1954363
Re-apply the cooler and check the thermal paste.
Make sure the fan header that is connected to the pump is set to 100%
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1954374
ohh lol
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1956118
The overclock has remained the same as with the 212 Hyper, 4.0 Ghz. I don't know why the temperatures would go up by 10 degrees on just changing coolers, especially going to water.
Biggest misconception is that going to water will drastically drop your temps, and on a gpu that's true, but not on cpus'. Especially with an AIO.
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1956186
Seems relatively high. My idle (3570k @ 4.2Ghz, H100 not the i version) is around 34*C average, with one core always being around 37 or so. I would re-apply paste, re-install, and see what happens. Maybe its a bad "set."
Also, make sure you take off the plastic that is covering the copper heatsink  :lol:  :lol:
Desktop: ASUS ROG Maximus V Formula - 3570k @ 4.2 Ghz - Gigabyte GTX 670 WF3 - G.Skill 16 GB 1600Mhz - Antec 900W - 128GB Crucial M4 - 2TB Hitachi HDD - NZXT H440
Mobile: Nexus 6P (current)  - Razer Blade 256 GB Laptop
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1956433
I have a 4770k from a bad batch it seems, I can't go any lower than 1.370v at 4.4ghz, despite this it idles at 22c and hits 61c on average during gaming, ofcourse it goes all the way to 77c when running Prime95 though... this is with the older H100 though.
AMD Ryzen 1700x
ASRock x370 Taichi
Corsair Vengeance RGB 16GB GDDR4 3200
EVGA GTX 1080 Ti K|NGP|N
Fractal Meshify C
Samsung Evo 960 Nvme M.2 500gb & WD Blue 1TB
Corsair TX850M Gold
Alienware AW2518H 240Hz Gsync
Audioengine A2+ & Sennheiser HD6xx /w Fiio K5 Pro
Deepcool Captain 240Pro V2
Vortex Race 3 Cherry Mx Red
Corsair Vengeance M65 PRO RGB
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1956571
I wasn't expecting a massive drop, but at least a few degrees lower, rather than several degrees higher.
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1957043
Absolutely. You should be at least equal. Since you're higher, I am assuming it is installed incorrectly/not making full contact, or your unit is faulty. Either way, goodluck!
https://linustechtips.com/topic/146340-heat-problems-with-h100i/#findComment-1957068
