I am wondering if I got enough power to have two GTX 770. ( Silver Power SP-S750 750W PSU)
My specs are :
Intel Core i7-4770 Processor
ASUS Z87-A, Socket-1150
Kingston DDR3 HyperX 1600MHz 8GB
ASUS GeForce GTX 770 2GB PhysX CUDA
Kingston SSDNow V300 120GB 2.5" KIT
Samsung DVD Writer, SH-224DB
Seagate Barracuda 2TB
Noctua nh-u14s
Three 120mm led fans
One 140mm led fan
One 200mm led fan
When looking into my Asus Geforce GTX 770 it said it needed 300w compared to other Gtx 770 which needed 250w.
Im thinking about buying Gainward GeForce GTX 770 2GB PhysX CUDA at this moment
Will my Silver power 750w survive it or should I think about getting another psu before getting my second gpu?
https://linustechtips.com/topic/146307-enough-power-for-this-badboy/
750w is enough for sli770 but that thing looks creepy. Dont know the brand or anyting.
Edit: Its apparently a seasonic so it should be good!
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
http://www.overclock3d.net/reviews/power_supply/silver_power_sp-ss750m_750w_review/6
Your PSU checks out to be fine. If you don't need the HT for work and intensive applications, I would go with an i5k instead. Also consider 4GB 770's if you plan to do 1440p or keep them for a while.
Error: 410
