keyboard Creating my own custom keyboard, but I need to create a custom PCB, how to get help?
42 minutes ago, Sondre The Highlander said:Is there discord servers for custom keyboards or people who are enthusiastic about PCB design?
The Keyboard Atelier is a Discord for custom designed keyboards (including PCB and case design): https://ai03.com/designer-resources/ (it's the link on the right).
There are also heaps of different tutorials and other information resources out there, including ai03's keyboard PCB guide: https://wiki.ai03.com/books/pcb-design/page/pcb-guide-part-1---preparations
Or from Keyboard Atelier community member harky: https://guide.zykrah.me/
Or Sleepdealr's RP2040 (different MCU) guide: https://github.com/Sleepdealr/RP2040-designguide
And much much more, some not even specifically keyboard related (because PCB information is relevant, whether it is for this PCB or not).
After a few projects and some informational threads I've made on this forum about keyboard's and specifically their PCB's I know my way around a keyboard too.
The DRC errors you often run into with keyboard PCB's can usually be ignored, as they are actually just non-issues (such as 'overlapping pads', like you'd have on the rotary encoder/switch in the top right of the board). Without knowing what the errors are, it's difficult to say what's going on.
You can post a screenshot of the DRC errors and I could give some guidance as to what they mean and why they're there?
I suspect some of the errors you have are legitimate, because I do see some issues in the PCB screenshot. The traces for the ISO Enter appear to be going through a hole on the board and/or are not connected and the diode top right of the ISO Enter is going to interfere with the stabilizer.
