HELP ping problems in csgo and other online games
Fiveros
My internet speed i 350Mbps download and upload 300, but in games sometimes ping is going up and down idk what to do or how to fix
Your download speed and upload speeds have nothing to do with your ping. Ping is used to measure latency. It's the distance between you and the servers. If you're far away from the server or you using WiFi then you're going to get issues. Other issues could be that the server is under load.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
i am connected with Ethernet cable, 3 weeks ago everything was okay and now not, for 3 weeks i have this problem, only thing i have changed was the name of my wifi, idk i didn't touch anything in modem settings only changed wifi names
Ping primarily depends on the distance between you and the server you're communicating with. Plus additional overhead from intermediate servers (e.g. your ISP). Depending on how busy these servers are, they may take more or less time to forward network packages. And depending on how busy a route is, packages may also travel along other routes to reach the server, which can increase/decrease latency as well.
This means most of the stuff that influences ping is outside your control. The most you can typically do is select a server as close to your location as possible.
I recommend doing a ping plotter. It tells you what is causing the ping spikes.
https://www.pingplotter.com/
Another thing I would try is to change your DNS servers from your ISP if it is set to them to a public one like googles or cloudflares. More than once I have run into outdated records that have caused me huge headaches.
Comp Specs:
CPU: AMD Ryzen 9 5900X ||  CPU Cooler: Noctua NH-D15 Chromax Black Air Cooler ||  RAM: Corsair Vengeance RGB Pro 32GB (4x8GB) DDR4 3600  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD 1 : Sabrent 2TB Rocket NVMe 4.0 Gen4 PCIe M.2  ||  SSD 2: Crucial P1 2TB NVMe M.2 ||  GPU: ZOTAC RTX 3080ti AMP Extreme Holo  ||  PSU: Seasonic FOCUS GX-850  ||  Case: Fractal Design Define 7 XL  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Corsair K95 RGB Platinum XT  ||  Monitor: LG UltraGear 32GN63T & MSI Optix G271 (x2)
