Gaming Issue : Please Help
Go to solution Solved by BetteBalterZen,
Are you absolutely sure that you use the EXACT same video settings, both under Graphics and Advanced Graphics? Some settings really tanks the performance, such as grass, shadows, anti aliasing, and particles (in some situations) and under Advanced Graphics, the two Extended settings require a lot performance too.
If you use the EXACT same settings, then as 191x7 asks, do you use single or dual channel RAM? And also, your system may be thermal throttling causing low speeds which would also hurt performance. You should check all temperatures using HWiNFO.
Hello folks, i have this system with Ryzen 5 5500u and its iGPU radeon 7, 8 GB 3200 MHz Ram, before getting this i saw some youtube benchmarks and in GTA 5 they had around 50-60 FPS but i am not getting that that much i get around 250 FPS only, i tried overclocking with Amd apu tuning unit and amd controller and doing a few more simple tweaks and ensured i have same graphics settings as they had still nothing better, Please provide some tips and solution
https://linustechtips.com/topic/1460141-gaming-issue-please-help/
1 stick of RAM? get another 8GB 3200mhz stick so it will go into dual channel mode which double the RAM bandwidth which also really benefit the iGPU performance.
1 8GB stick or 2 4GB?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
-- Threads merged --
Please keep an issue to a single thread, in the right sub-forum (Troubleshooting in this case).
4 minutes ago, Siddharth Goswami said:
8 GB X 1
Ryzen CPU-s are severely bottlenecked when using RAM that doesn't work in dual channel.
In your case, that bottlenecks the integrated GPU too, since it shares the system memory.
