I currently am using these fans
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4814839
I was thnking about switching to these since everyone says they are so good
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
These have better CFM and static pressure than the ones i am currently using i am mostly just wondering how much of a temp difference i am going to see with my 240mm radiator i use.
My rig: Case: Corsair 760T CPU: Intel 4690k MOBO: MSI Z79 Gaming 5 RaM: 16gb HyperX SSD: 256gb Samsung pro HDD: 1tb Toshiba PSU: Thermaltake smart 750 GPU: 1x GTX 1080 Founders edition
https://linustechtips.com/topic/14598-which-fan-is-better/
Your original question: Which is better?
If you can get over the colour then the NF-F12.
as for
... just wondering how much of a temp difference i am going to see with my 240mm radiator i use.
Temps and noise levels will have an improvement but you gotta way up the cost of getting new fans, is it worth it to you? are you unhappy with your current performance?
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-162252
It is important you tell us what radiator you have or what AIO unit.
Noctua NF-F12s are the best fans out there. They will give you lower temps. By how much its impossible to say. It depends on a lot of factors such as the temperature inside your case. What your watercooling set-up is etc.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-162311
as for
Im not worried about the cost of the fans much. I am using the XSPC raystorm RS240mm kit right now im idling at like 28C - 30C which is somewhat disappointing to me because I thought I was going to be idling/loading at lower temps although last week when it was much colder outside I was idling at like 26C. Also I haven't overclocked mainly because im kinda hardcore about my cooling, and i don't like a loud computer. So I am not really sure what to expect from this cooler, this my my first "Custom" loop build the main reason i decided to purchase the kit was because I had decided to go with a Res/Pump combo anyways and i had heard the block for these kits was one of the best on the market so yeah.
I believe my ambient room temp to be anywhere from 74-76F (The thermostat says 77 but that's for the house and I don't have a temp tester)
CPU: AMD FX-8150
Also i found this link to some testing people did with an i5 2500k and they were idling at 31C but this is an intel chip so idk....
http://www.thinkcomputers.org/xspc-raystorm-750-rs240-watercooling-kit-review/5/
Just tell me if any of you have a good guess as to what type of temp drops i could see. Thanks a lot.
EDIT: Also if anyone can find anymore testing people did I would LOVE to see it, that was all i could find.
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-163223
If your temperatures are directly relational to only the fan performance, ie. other factors aren't directly relating to performance change, then you should get a few degrees improvement under ideal situations, maybe 3-5 degrees. If you've done your best to eliminate other parts of your loop that may be impacting your temps, then changing the fans can help. Just keep in mind that watercooling really shines at higher temperatures so while you may not see a big jump in idle temps, your max temps at overclock should improve.
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-165063
I believe my ambient room temp to be anywhere from 74-76C (The thermostat says 77 but that's for the house and I don't have a temp tester)
Are you living in an oven?!
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-165065
I think you need some liquid helium for you house.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-165074
I think he might mean Fahrenheit since the highest recorded air temperature on the planet is in the 50's C.
Oh yeah sorry I did mean Fahrenheit :P
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-165788
Noctua <3
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-165869
http://www.frozencpu.com/products/10210/fan-654/Scythe_Gentle_Typhoon_120mm_x_25mm_Fan_-_1450_RPM_D1225C12B4AP-14.html
These are practically the best radiator/static pressure fans out there. They undervolt very well, they run quiet and they have great airflow/static pressure.
https://linustechtips.com/topic/14598-which-fan-is-better/#findComment-169878
