Moved to the Cooling subforum. The Forum Suggestions subforum is for suggesting features for the forum.
https://linustechtips.com/topic/1452482-no-cpu-cooler/#findComment-15545776
5800x does not come with a cooler, do not power the machine up without one.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1452482-no-cpu-cooler/#findComment-15545779
You can POST under BIOS, see the temp reach 95C under 30 sec and then your PC will shut down
Better not do it 🙂
https://linustechtips.com/topic/1452482-no-cpu-cooler/#findComment-15545803
