Phone upgrade - iPhone 14 Pro or iPhone 11 Pro
Solved by MonkeyBomb,
Why not the 13? Cause of the number?
With the 14 series coming out soon the 13's may drop a bit in price.
I'm not a fan of the rounded edges, I really like how the 12 series and up feel. I had a 12 Pro Max and now a 13 Pro Max and honestly it's hard to notice any difference. Both get great battery life and really decent screens.
If you can find a used 12, it's a good device
