Xbox controller not detected when plugged in to the monitor
IAmAndre
Hi guys,
I'm using a Xbox One Series controller on my PC. It works totally fine when I plug it to the PC, but it doesn't when I plug into the USB ports on my monitor. USB sticks are detected without any problem though. Actually even the controller is detected in Device Manager (under Xbox peripherals) and it rumbles when I plug it. However, the logo on the controller doesn't turn on and it's not detected by any game. Again, it works totally fine when I plug it to the motherboard. Anything I could try?
Thanks!
Pluh it in your pc instead💀 its just getting power from your monitor.
10400f
16 gb 4000
1650 super
z490 msi
p400a digital
games i play: krunker (sometimes), valorant, and csgo
The fact USB sticks work clearly shows that the USB hub on the monitor is capable of sending both data and power.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
