First PC planning looking for opinions
Solved by RONOTHAN##,
11 minutes ago, skamnox5 said:Also, should I just hold off a bit since new things are about to get revealed.
Yes, you really should.
I wouldn't really recommend anything in that system anyway, 980 Pros are really expensive and not noticeably better than a Gen 3 drive for 98% of people, the RAM kit is pretty expensive, the PSU is very expensive for what it is, and that cooler is downright a ripoff. That said, new stuff will be out within a month or two, so I wouldn't buy any of this in general, either waiting for AM5 to release and getting that, or waiting for AM5 to release and AM4 gear to go on heavy clearance.
