Port Forwarding won't work on new Hub
Solved by Zalosath,
Solution is trivial and stupid.
Port checker was not working, I tried 3 different ones and it seems like they all look for some kind of header to pull to verify the port is open, for game servers and the like, especially for games under development (like mine), they won't have this header file and thus will fail the port check.
Actually testing the connection with another device is a much more fool proof way and I will not be using a port checker again.
