Would it be better to build an old High End Rig consisting of used parts, or a new Mid End Rig Consisting of all brand New parts, Max budget $600.
30 minutes ago, Dog 234 said:Budget (including currency): $600
Country: U.S
Games, programs or workloads that it will be used for: Gaming
There are parts you can get used that I will still trust, like a case or RAM or SSDs
There are parts that I refuse to buy used, like power supplies
Do you have any parts to start with? Or are you building a PC ex nihilo, out of nothing, and have to buy every part?
It'll be up to you how much you trust whoever you're buying from, but your best mix of piece of mind and performance is probably a blend of new and used parts.
Since the GPU market crashed there are plenty of used options there that'll play whatever you need, specifically because there is no (worthwhile) new sub $200 GPU.
If you go used, be very careful about compatibility. It's easy to end up with parts that don't quite work together (like a motherboard that needs a BIOS update before it'll accept the CPU you bought) even though you got a great deal on all of them.
