The 8 pin on my motherboard needs a specific 8 pin connect but my psu 8 pin is different
Solved by Poinkachu,
1 minute ago, ShiroEerie said:Its a i3 8100 and a b360m k Asus prime,
1tb hdd8gb 2400 mhz avexir
Strikex 500w +80
this is not a high power one right? so it works with the house on square?
Just use the power cable as is.
All of our PSU cable for CPU are most likely like yours.
Same goes for the motherboard terminal shape.
In the link I gave earlier I put my Corsair HX CPU cable plug shape, and my motherboard CPU terminal shape.
It's the same as yours.
