Guys need some help regarding psu
Max69
I want to buy a psu
I want to know if system pulled psu are ok to go with
The option i am having in used sections are antec (EA 500d) 500watts 80 plus bronze psu
Second coolermaster psu non rated
Or i should just sacrifice my gpu and increase my budget to get a new corsair cv 550 or aerocool lux rgb 650 watts semi modular
Also dropping the image of antec psu
6 minutes ago, Max69 said:
I want to buy a psu
The option i am having in used sections are antec 500watts 80 plus bronze psu
As @--SID-- noted, what you plan to power with it is important, but remember that with used, there are no guarantees and usually no warranties. You mention the CoolerMaster is not rated, I've never heard of a PSU not having a rating, which for me would be a major red flag. That said, I can't speak for or against Antec's quality, but I have noticed their stuff is priced cheaper, and you usually get what you pay for.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
My bet is no 80+ rating.
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Another major red flag in my book.
2 hours ago, --SID-- said:
What CPU and GPU are you going to power with it?
I am going to use i5 10500 the gpu is gtx 660 (temperory)
Yeah bro coolermaster one doesn't have ratings
And i am getting a week of checking warranty for antec one
The Antec is at least 10 years old. Don't buy it.
You definitely need a better PSU than all the units you mentioned above. Do you have a link to a webshop in your country?
