I have a i7-12700k I currently have a 2 fan aio. Should I instead get a 3 fan?
also what’s a good temperature reader program.
The ones I’ve been using have been showing that during gaming on average it’s between low 60s and high 70s but one of the cores could spike to 100 is this OK? some games like battlefield 2042 can make it be in between the 70s and 80s. but any games I play a couple of the cores always spike to 100 for a couple of seconds.
While not Gaming it’s mostly in the 30s.
Edited by Bryandbc01
https://linustechtips.com/topic/1440275-cpu-cooling/
Are your temps bad?
https://linustechtips.com/topic/1440275-cpu-cooling/#findComment-15460121
Depends on the CPU. Some Intels are rated safe to 100C. The i7-12700K is also. Look in Package Specifications.
https://www.intel.com/content/www/us/en/products/sku/134594/intel-core-i712700k-processor-25m-cache-up-to-5-00-ghz/specifications.html
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1440275-cpu-cooling/#findComment-15460161
HWinfo is a good software for reading temperatures and all other sensors. Your temperatures are not that bad for a dual fan AIO. I don't think a three fan is going to change unless your AIO is a cheapo no name.
The problem with temperatures is that it's highly dependent on air flow within your case. I had mid 60's on the CPU during Rocket League, but I ended up adding several fans and directing air flow from the bottom of the case to the top (since my case has a solid front). It actually took me weeks to figure out how best to move air in my latest build. But with the same AIO, I dropped my CPU temps in the same game to 48 to 55 C. Which is a great improvement in my opinion.
You might need to post some more details and provide photos if you want better direction. Also, the solution to lowering temperatures might not be cheap.
https://linustechtips.com/topic/1440275-cpu-cooling/#findComment-15460179
I would try to keep it under 85, just to get it to not throttle. I would get  Arctic cooling Liquid Freezer II 280, 360 or 420. You can get it in a-rgb if that's your thing. Best aio on the market imo, no USB control, pump is synced with PWM fan speed and no lame software to control fan speed. Just use the motherboard or your favorite program.
Edit: I would try to keep it under 85 (In a gaming scenario)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1440275-cpu-cooling/#findComment-15460186
