Search In
  • More options...
Find results that contain...
Find results in...
i5 12400 and lian li dynamic o11 mini
cyberdan88
 Share
I512400 STOCK COOLER
16GB DDR4 3200 KINGSTON
MSI 3060 12GB
MSI TOMAHAWK B660 WIFI
1TB M.24.0 MORE ADD IN FURTURE
IN A LIAN LI O11 DYNAMIC  MINI WITH 9 SL FANS
PS IT MY FIRST BUILT
wat cooler be best for the cpu in question as idle is 50 c and at load it 70 to 80 c
the i5-12400 will not be very hard to cool. How much money do you want to spend? The o11 Dynamic was built for water cooling but works just fine with a decent air cooler. What fans do you have on the case?
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
Trash beauty:
Xeon X5550RX 570 4GB (defective) -Fattydove Racing 240GB - WD Blue 320GB - HP Z400 - 6x2GB DDR3 1066 - EVGA 450W3
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
have 9 lian li fan sl 120
i have 50 pound to 100 pound
As a previous owner, I can assure you an 011 mini isn’t going to be the problem trying to cool a 12400f.
What is your airflow pattern? I used a 5800x and a 3090 @ 400W in that case beautifully.
ITX & Ultrawide Enthusiast
5 intake 4 exhust with stock cooler
wat cooler wood be better than stock cooler as at idle it 50c and 70 to 80c on load need
ps it my first biuld
What cooler wouldn't be?
Your "PC master race" thing is cringe.
011 Mini is really kind of designed for water cooling/AIO's but you also really don't need an AIO with a 12400.
That being said an EK Basic 24o/Arctic Liquid Freezer 240 would be more than enough.
Nearly any single tower cooler would also be plenty. DeepCool AK400 or an Arctic Freezer 34 eSports for a few suggestions, both in the $35 US range.
 Share
