Please help with PC shutting down randomly
Solved by DCCFan,
Hi, sorry to hear your PC keeps shutting down. I'm no expert but something similar happened to my son's PC and it ended up being the motherboard. If you already changed your PSU then the possibility of it being mobo related is high. You could update BIOS and see if that helps. Maybe someone else will have other suggestions. Good luck!
Also, you could take the motherboard out of the case and test it outside of it just to rule out some sort of short.
