Can anybody help with this "unlisted" Motherboard model? Trying to find right model so can get updated bios.
Solved by jaslion,
12 minutes ago, Bryan-10EC said:I just like to check for latest Bios version since most motherboard have at least one revision to address some issue that popped up.
What happens in there is some security issue that requires an updated bios?
I don't like this concept. Even Dell gives easy bios updates.
And thank you for the quick response.
Basically every manufacturer I know has had or currently has boards that never got or will never get a bios update. It's sadly kinda normal.
If it works not it's good. That and most issues are fixed on the os side of things or other means.
