Previous post edits in the forum threads are not always successful.
Solved by colonel_mortis,
7 hours ago, Tan3l6 said:OK, It's more than likely that the Chrome cache or settings cause theses errors.
For example can't accept Guru3d cookies:
Edit: it might be Chrome's "Undetectable Adblocker" plugin that might be the cause. For example caused Guru3d cookies accept menu to not work at all, after disabling it all worked fine.
Yeah adblockers are pretty prone to causing problems like that, and there's not much we can do about it because they are designed to mess with the page. If it happens again with the adblocker disabled, let me know, but otherwise I suspect that's the issue, especially as it's not a widespread issue.
