We have two machines both using windows 10 and they both have a 2.5 drive dock built in. When we make a new folder in the swapable drive and save files to it , then move the drive to the other pc , it will not allow access to the files in the folder we just created. Says "don't have permission" but you can click continue and it opens the folder but the folder is empty.
The drive however has a bunch of pre existing folders that are 100% accessible. Not entirely sure how these are all fine but seems like new folders are just not working the way the existing folders are.
https://linustechtips.com/topic/1436007-external-drive-wont-allow-acess/
Do you have any permissions set up on the drives and/or directories? Sounds like it's not inheriting the permissions when new objects are created.
Also, does the permission error only happen from one computer to another, or both ways? For instance, moving it from PC#1 > PC#2 has an error, but #2 > #1 does not.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
to my knowledge , I myself did not specifically tell the machine any sort of permissions. so whatever windows would have as default would be what it's using
(i'm remotely helping someone with this issue so the machine aren;t in front of me)
I did just now ask them to try it backwards , and now folders and files are seemingly (randomly) not showing up or showing less files or smaller folder sizes indicating it either can't see or isn't copying files to the drive.
I'm guessing I don't have the drive set up correctly to be able to be swapped between machines , not sure what i'd have to set though
I made some progress,i was able to access the files by running WinRAR as TrustedInstaller and using it to navigate to the files and launch them.
I used ExecTI to do that: https://winaero.com/download-execti-run-as-trustedinstaller/
Maybe that will help you access the files.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
2 hours ago, Vishera said:
4 hours ago, Kid.Lazer said:
i figured it out. we had to reboot the computers between drive swaps so the machine knew that at some point the drives were removed. otherwise the machines never knew the file configuration changed and thus tons of errors.
