Im currently using an xbox one controller, one of those old ones that don't support bluetooth, with the wireless adapter for PC, and whenever I play any platformer, or retro titles, I always notice that the input lag is pretty bad, so I was wondering if there is any better wireless controllers for PC, when it comes to input latency
I knwo the 8bitdo ones require that adapter wich ads latency, so I think 8bitdo is a no, also any nintendo controller also requires the same adapter, so no aswell, do the xbox controllers that support bluetooth nativly have better latency?
What is the best way to connect a controller wirelessly to minimize latency? My mouse is wireless (logitech g305) and its input latency is pretty much unoticable, actually I think it has less lag than the old wired mouse I used to use before it, y isn't it the same with controllers?
https://linustechtips.com/topic/1433060-controller-input-latency/
I use an xbox one controller (the one s one) with bluetooth and have no issues on phones or on pc. (I plug it into my pc via the cable most times tho)
No noticeable latency
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
2 hours ago, cstrachn said:
First off are you sure it's the controller. if you use the keyboard do you still get latency?
I have the SN30 and it works pretty good. and a ps3 controller that runs great wired and wireless
I mean, if I compare wired controller vs wireless controller I clearly notice the diference
On the video (first one wireless, secound one wired) I caught like one extra frame on wireless, and thats on a 24fps camera
I guess if I want super low latency I really have to go for wired then, I was wondering if there was an option, cause I never noticed that kind of lag on my mouse, but maybe its because the kinds of games I play on mouse are less likely to show lag (i don't play many FPSs)
