What OS/Sofware should I use for my home server/NAS?
NorAmI
Hi all,
I want to make a home server with "old" pc parts that I have.
I would like it to be a NAS (local storage)
and be able to run docker containers for things such as nextcloud, a gitlab runner and some other stuff.
and if possible a graphic ubuntu, to be used as second pc for simple excel work and googling stuff.
As for specs it is my old pc components.
Z170 MB with a i7 6700k 16Gs of 3000Mhz RAM
256G nvme SSD and a seagate 2 TB HDD
For the NAS part I plan to buy some other HDDs
So my question here is, what OS / Software combination do I need  to achieve that result ?
36 minutes ago, NorAmI said:
Hi all,
I would look into running proxmox as your hypervisor, and then you can virtualize whatever you want under it.
I run proxmox with truenas, multiple Ubuntu VM’s (one of which hosts docker containers), home assistant, and windows all running. Lots of YouTube videos showing and explaining how this works.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
I don't want the VM overhead so just have an Ubuntu install and everything as dockers or snaps, and samba running directly on the host.
F@H
GPD Win 2
