Sound Blaster X3 external USB device - no support for a headset?
Solved by H713,
You mean like a normal TRRS to TRS + TRS cable? Here's a generic example:
There are multiple connectors used for literally everything in the audio industry - don't expect manufacturers to always choose the one you happen to use.
