Fan upgrade suggestions
kazumi_mikuzi_x
I'm looking for fan recommendations for maglev fans. I've been debating the corsair line for 120mm fans but I'm gonna be using it for a custom loop primarily on my rad(s).  I've seen a lot about maglev's being reliable and long lasting while being overall quieter so that's the main reason I'm looking for them.
Price isn't too big a deal, preferably with RBG so I can use them towards the builds theme. The currency is GBP though I'm not too concerned if I need to find other sellers to get the suggested end solution from.
If you're looking for maglev rgb fans, Corsair ML Pro is the only thing that comes to mind.
Phanteks T30 fans with their Halos fan frames is more expensive but probably the best option available.
How do the halo fans differ from thr maglevs?
The Halos fan frames are just a cosmetic addition and not case fans themselves. https://www.phanteks.com/Halos.html
