Failed To Establish ieee 802.3 ad connection synology
3 hours ago, Needfuldoer said:Leave all the NICs independent, use one for the Plex client and another for file management. It's less than ideal, but it's a solution you can implement for free with the equipment you already have. Just remember to give static addresses to all the ports you plan on using.
Β
Either that or you'll need a managed switch. (If you go this route, get one with SFP+ ports so you can do 10 gigabit in the future.)
That's also what I did before upgrading to 10Gbit. Β
Β
I actually went in stages, first to a the spare Gigabit port on my motherboard (its a PC rather than an off-the-shelf NAS so had two ports already) then to a 1Gbit switch with two 10Gbit ports, DAC from the switch into my NAS and the main machine I would be moving files from in the copper port.
Β
I then moved to a multi-gig switch before eventually moving up a tier to one with more faster ports (they're all in my sig)Β as I knew I would be getting Gigabit FTTP (hopefully later this year) which would add yet more contention, plus I wanted more than one client to be able to copy to the server and didn't want the mess of another network, another switch or multi-port NIC and a ton of extra cables.
Moving to 2.5Gbit is probably a decent compromise, but I wanted to go all the way as some of my storage is SATA SSDs.
I actually have LACP on my router so that once I get FTTP I can concurrently use the 5G backup though will likely replace that with a 2.5Gbit capable model.
