Monitors and Display Issues
Kelvin_r
I'm having issues with getting my monitors to display using display ports. I have swapped multiple monitors as well as a tv to attempt to get a signal but it isn't working. I have used display ports as well as hdmi ports going to both the graphics card and the motherboard. I have checked the on board settings for the monitors as well. Does this seem like just a settings issue or might this be something else? The part that I am confused about is that the motherboard also isnt sending a signal?
 Help?
Do the cables work? What're you plugging stuff into? What graphics card? What motherboard?
Do you have integrated graphics? If it's sending signal through the GPU then the motherboard won't output.
You should restart between swapping the cables if you're having problems?
Are you sure your system is booting and not also crashing?
I dont have on board .....
Motherboard: ASUS PRIME Z690-P WIFI ATX DDR5, Wi-Fi 6, 2.5GbE LAN, 4 PCIE X16, 1PCIE X1, 3X M.2 SATA/PCIE
Video Card: GeForce RTX™ 3080 Ti 12GB GDDR6X (Ampere) [VR Ready] (Single Card)
Ive been swapping between using cables... but havent interchanged multiple display port cables...
My pc seems to boot normally.... but cant confirm as I cant see anything...
You have an F series CPU? then the motherboard would never output video anyway.
DP cables are really finnicky
can you see a post code or LED indicators? Does numlock work?
