rtx 3080 power supply question
Gorn21
Go to solution Solved by Tinitis,
9 minutes ago, Gorn21 said:
the problem is that the 6 +2 cables i have split into 2 and dont know if it will still be enough if i use 2 od these cables to fill those 3 slots.
Yes, it will work. I'm using two PCIe cables from my Corsair HX750i to power a 3-connector EVGA 3080 FTW3.
Hey there i have a question regarding the new 3080 3 8 pin cards. I am thinking about buying a 3080 and am not sure if i can buy a 3 8pin card with my current powersupply (Corsair RM850x) which has 2 pcie cable s with splitting 6+2 kables and one left cpu 8 pin cable. The question is do i need 3 8 pin cables to power the gpu or can i use the 2 6+2 ones? Or can i use the 2 splitting cables one each and use the left cpu cable for the last slot?. shouldnt it be possible i will search for 2 8 pin cards.
You're fine using the cables that you have. 6+2 or 8 pin are perfectly fine to use in whatever configuration you have available. It will work and is perfectly fine to use.
thanks alot for your quick answer i really didnt want to buy such an expensive card only to notice i cant use it.
DO NOT use the 8-pin CPU power cable, though.
DO NOT try to force that 8-pin CPU power cable in.
8-pin CPU is NOT the same as 8-pin PCI-E.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Thats why i am asking 1000€ is a lot of money which i dont want to burn because i made a huge mistake.
