Buy APs or go mesh
https://linustechtips.com/topic/1425912-boosting-wifi-range/#findComment-15359631
1 minute ago, star_weaver said:
Signal inside is fine, it's once I walk outside, like I could be outside right next to router and through the wall signal has dropped to 20% or so.
Right- these will be your options though.
An outdoor rated AP more likely, or moving a mesh system closer to where you want to be outside
https://linustechtips.com/topic/1425912-boosting-wifi-range/#findComment-15359638
