Should I go with an I3-10100 system or Athlon 3000g?
Solved by YoungBlade,
What is your use case? If you intend to always use integrated graphics and you are gaming, then the AMD route would be better, but it would be even better if you got the i3 10100 and then purchased a dedicated graphics card in a year or two, rather than upgrade to a Ryzen 5 5600G or whatever.
The better Ryzen APUs are more powerful as CPUs, sure, but the integrated graphics are a huge bottleneck. The i3 paired with a used RX 570 or 1650 will overall perform much better for gaming, and those cards will almost certainly cost less than something like a Ryzen 5 5600G once you have the money to upgrade.
