deepcool gammaxx 400 pro blue led dual fan installation
Isabella00
hi
How do I know if CPU cooler {deepcool gammaxx 400 pro} is compatible with my motherboard {msi b560 a-pro}
I worried about deepcool gammaxx 400 pro dimension
does deepcool gammaxx fit to my motherboard without problem
3 minutes ago, bmx6454 said:
it lists lga 1200 as a compatible socket in picture number 2, so it will work with your board.
i know that but
its big CPU cooler
There have been some intel motherboards people have claimed some bigger coolers didn't quite fit, because the mounting brackets made contact with a capacitor or something else on the motherboard. This one looks like it would fit.
4 minutes ago, Mel0nMan said:
That will probably fit. I'd be surprised if it doesn't.
That will probably fit...!!!💔🥺🥺
I want a sure%100 answer, my friend
15 minutes ago, RONOTHAN## said:
Not that big. It shouldn't have issues with interferences with the VRM heatsinks.
WHAT ABOUT issues with interferences with  RAM Kingston FURY Beast DDR4 RGB Memory
dimension
Height 41.24mm
dimension
Height 41.24mm
It's a 120mm single tower cooler. It's not going to overlap your RAM slots at all.
If you don't believe me you could simply measure out 106mm centered over the CPU socket.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
6 minutes ago, Isabella00 said:
-snip-
And the cooler only is 25mm wide centered on the socket. Those fans can be placed higher on the cooler to allow for more room for RAM, just like with Noctua coolers. As long as your case has room for a taller fan.
On top of that, unless you're using all DIMMs, you shouldn't even have to do that.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Looking now, the RAM clearance height for the cooler is clearly listed and diagrammed on Deepcool's product page. (Edit: See the diagram IkeaGnome posted above.)
You should note, however, that they've measured the height above the CPU heat spreader (which will vary with the type of CPU and thus the type of mounting used), not the actual height above the motherboard PCB, which will be greater.
