https://linustechtips.com/topic/142387-sapphire-vs-xfx/
sapphire
also add a poll so you can get a better idea
Specs
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900668
Sapphire all the way, xfx isn't as good as they used to be and rarely overclock decently anymore.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900670
their psus are still amazing, guess its the only thing keeping them in the market
Specs
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900690
I like Sapphire better. They tend to have cheaper cards for the same (if not better) performance.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900695
Very true, thank goodness they are smart enough to rebadge SeaSonic units.
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900712
Sapphire gets my vote on this one, but if the xfx is cheaper get it, seriously don't waste money though getting the sapphire if its more expensive
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900787
Xfx>>>>>sapphire.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1900896
sapphireeee will rape xfx
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1901152
sapphire by a landslide...
3930k | RIVBE | 32GB Dominator Plat. | Titan XP | Intel 750 1.6TB | Mellanox 10Gb NIC | AX1200i
Custom TJ07 | 2xD5 pumps | EK Supremacy EVO | EK Titan XP | EK RIVBE Block | Cu Tubing | 25x120mm Rad
Samsung U28D590D 4K | Leopold Otaku w/Browns | Corsair M65 | Corsair SP2500 | Sennheiser HD595
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1902230
Sapphire all the way, I've actually never seen a Vapor version of the 290, must be new release cause I can't find it anywhere too.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1902291
the vapour x cooler will probably be 10c cooler than the xfx one.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1902524
The Sapphire card will be a better choice as it has a backplate which helps strengthen the PCB's rigidity and with its triple fan cooler it should be able to cool the card with lower RPMs than the XFX one so it would be quieter. What is the price difference between those two cards and which store are you planning to buy them?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1906260
At first I thought this was a brand war thread from the thread lol.
But in this case like it was stated a lot before, Sapphire is the way to go. The XFX coolers (well at least the newer ones) are really complete rubbish and can be compared more to stock coolers than aftermarket ones. They just arent as good as they used to be in the GPU business anymore.
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1906540
just arent as good as they used to be in the COOLER design
anymore.
Fixed.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1906562
Sapphire ftw
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1939642
Between the two cards you listed. The Vapor-x wins my vote.
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1939678
Just get the Tri-X one from Sapphire. Same price as the xfx, but way better cooling performance.
My Rig "Jenova" Ryzen 7 3900X with EK Supremacy Elite, RTX3090 with EK Fullcover Acetal + Nickel & EK Backplate, Corsair AX1200i (sleeved), ASUS X570-E, 4x 8gb Corsair Vengeance Pro RGB 3800MHz 16CL, 500gb Samsung 980 Pro, Raijintek Paean
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1941770
Easily the Sapp R9 290 VX! I happen to have a Sapphire HD5770 VX and it's been serving me, or rather, my brother well all these years. With the VX cooler, it runs cool and attest to its longevity.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/142387-sapphire-vs-xfx/#findComment-1941887
