RTX 2080 VRAM temp same as hotspot?
necrophagist
Hello,
CPUID Hwmonitor and GPU-Z both show the hotspot and memory (I assume VRAM) as being the same; however, I've heard that they aren't the same. Also, I thought only the new 3000 series cards had VRAM sensors. Can I trust these programs? Is this hotspot temp actually my VRAM temp or not? I know it's normal for the delta between the core temp and the hotspot to be around 15 degrees as it is with me, but I've heard that GDDR6 throttles at 95C, which means that I would throttle when my core temps reach 80 degrees, right? But the throttle temp for the 2080 is 83C, so I don't understand. Is VRAM throttling the same as normal GPU throttling? Will I throttle when my hotspot reaches 95C even if my core temp is below the throttle temp? Thank you.
P.S
Hwinfo doesn't show my memory temps, only the hotspot temps
  • 5 weeks later...
i think it was a nvidia update. i had sub temps before that.
MSI x399 sli plus  | AMD theardripper 2990wx all core 3ghz lock |Thermaltake flo ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3000 MHz | Corsair RM1200i |150tb | Asus tuff gaming mid tower| 10gb NIC
usually close, dont worry about it
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
