Router wifi rated speed explanation ?
By
Nivekover
in Networking
in Networking
Solved by SignatureSigner,
there are limits to speeds over certain frequency
2.4ghz is around 150
5ghz is around 1300
(This also varies on the protocols used)
If you have 100mbps internet that is the max over any protocol you will get with your router.
Some routers advertise those speeds for longer ranges (thus they cost more) and some routers can handle those speeds with more devices connected.
Featured Topics
Dan1718 ·
Posted in Troubleshooting0 -
Zexer2020 ·
martixy ·
Posted in Phones and Tablets1 -
CentreMetre ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Graphics Cards8 -
6
10
