HELP
Go to solution Solved by tobben,
     i changed the motherboard and my baby is back in action!
congrats on getting a new motherboard and for getting it all sorted out  :)
may the previously glorious technologically advanced motherboard that has now turned into a brick rest in peace.
I just pu my cpu frequency at 3,9 in the bios and my pc doent have signal, it is powered on but nothing in the screen, please help, what should i do
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/142306-help/
are you running an unlocked CPU?
playing with base clocks can be dangerous
Linus once unboxed a Toblerone
https://linustechtips.com/topic/142306-help/#findComment-1899778
Did the cable from your GPU come unplugged?
no i check the cables
https://linustechtips.com/topic/142306-help/#findComment-1899780
no its locked
https://linustechtips.com/topic/142306-help/#findComment-1899781
no its locked
ahh
well, i'm not sure how you'd go about doing it, but the only fix i can think of that doesn't involve buying a new part is to find a way to bring the CPU to stock settings. Like i said, i have NO CLUE on how to do this, nor do i know if it's possible
https://linustechtips.com/topic/142306-help/#findComment-1899791
no its locked
well you should be very carefull with the overclocking then go step by step.. you will generally have alot of limitations and might run into a couple issues, should probably google your processor/motherboard and see if there is anything in particular that you need to take note of, when in doubt reset cmos.
that being said an unstable overclock shouldn't cause this, might leave your computer unable to boot, make it crash/bsod, even prevent you from going into bios if you were over eager, but it shouldn't get stuck booting without giving you a video signal.
https://linustechtips.com/topic/142306-help/#findComment-1899794
well you should be very carefull with the overclocking then go step by step.. you will generally have alot of limitations and might run into a couple issues, when in doubt reset cmos.
how can i reset the cmos?
https://linustechtips.com/topic/142306-help/#findComment-1899803
Maybe my psu died i used a very low quality turbox 850w under 70% efficiency yesterday i ordered a corsair ax860i but it wont arrive till wednesday
https://linustechtips.com/topic/142306-help/#findComment-1899811
I got power to gpu cpu fan and rear fan but my 2 other fans keyboard and moyse are dead and still nothing on the screen
https://linustechtips.com/topic/142306-help/#findComment-1899821
ahh
clear cmos ;)
https://linustechtips.com/topic/142306-help/#findComment-1899843
http://www.wikihow.com/Reset-Your-BIOS
this might help you abit, go look in the motherboard manual to find the cmos jumper if you have one, the manual should say the prefered way of resetting cmos on your motherboard, i hope you don't have a raid setup or anything of the sort..
https://linustechtips.com/topic/142306-help/#findComment-1899845
clear cmos ;)
i cleared the cmos and still got nothing
https://linustechtips.com/topic/142306-help/#findComment-1899936
I am going nuts what the fuck is the problem its 1.30 after midnight and all the shops are closed till tuesday morning
https://linustechtips.com/topic/142306-help/#findComment-1899986
So you can't even enter the bios? Do you have the option to test the CPU and GPU in another system?
unfortunately i cant it is the only pc in the house
https://linustechtips.com/topic/142306-help/#findComment-1900005
crap. I'm not sure if overclocking a non-K part can actually fry it, after all you only messed with the clock speed, not the voltage, right? But if even a clear cmos didn't get you anything, the only possible cause I can think of is a dead component.
may I ask what method you used to clear cmos?
https://linustechtips.com/topic/142306-help/#findComment-1900044
i tried both my manual suggested, i removed the batery and reinstaled it after a minute and i touched the cmos reset headers with something metal for 5 seconds
https://linustechtips.com/topic/142306-help/#findComment-1900063
well, that sucks, then. If you're sure it's not something as simple as a badly seated GPU or a loose 24-pin connector, this doesn't look good.
https://linustechtips.com/topic/142306-help/#findComment-1900079
the thing is if i fried something i have no clue what it is, i dont think is mu gpu because its fans are running, if i fried mu motherboard would anything else worked? And with a fried cpu i think you can enter the bios?
https://linustechtips.com/topic/142306-help/#findComment-1900098
Is it by chance am3+?
no its 1150 check my singnature
https://linustechtips.com/topic/142306-help/#findComment-1900123
I agree that it's most likely not your GPU. I'm almost certain your motherboard won't boot without a CPU. The bare minimum, if I recall that correctly, is a CPU, power and RAM.
https://linustechtips.com/topic/142306-help/#findComment-1900169
