I'm buying a 3070 Ti. I have 2 options. Does the difference boost clock are 1860-1815. Not important right? Both the same price. So want to make sure I get the best one I can with no issues reported on the models. Like gigabyte. HA!
As for what I'll be doing with the card; Gaming, Streaming and encoding stream with it. Rendering videos (rarely) if I continue that nonsense.
Options are:
Used for 3-4 months , never mined on.
EVGA GeForce RTX 3070 Ti FTW3 Ultra
Brand New In Box, never touched.
Asus GeForce RTX 3070 Ti TUF
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1422718-two-gpussend-help/
For the same price, I'd go with the NIB card here.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336495
Get the new one if it has no warranty issues.
Also, get Grammarly.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336497
To be fair EVGA has a much better track record for warranty and customer service than Asus. Also EVGA warranties their GPUs even if you buy them used. The caveat being since you are not the original owner, you lose out on a couple benefits. Double check this on their website, but last time I checked, the warranty starts from the date it was shipped, and you lose the cross shipping option on dead cards.
I much prefer EVGA, over any brand of GPU. I prefer any brand over Asus. That said, I would also tend to lean towards the new card. I would double check, though, some manufacturers want you to purchase through authorized vendors for a warranty. So if you are buying a scalped card, don't just assume you won't have a warranty issue.
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336505
I know I do this in text also, I skip words its quite that issue.
I much prefer EVGA, over any brand of GPU. "I prefer any brand over Asus."
Why is that? Anything over Asus?
I also usually always go EVGA. Since the 900 series (desktop) always. However I never had a new card before till the one in my system now. I settled for this one cause I couldn't find a ftw3 ultra or TUF.
25 minutes ago, tkitch said:
No real difference between them.
Get the new one to make sure you don't have any warranty ownership issues.
Also can't you transfer left over warranty on EVGA cards? Is that not true anymore?
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336521
My problem with Asus, is a personal preference, and likely my bad luck with their products. However lots of people like their products, and use them. So don't let that necesssarily discourage you.
EVGA will let you transfer the warranty. It's in their stated policy, see the link. It's not an issue at all, you'll even be able to add the card to your my EVGA account, no issue at all. I've done it it recently.
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336535
4 minutes ago, tkitch said:
Warranty transfers are always kinda sticky, so if it's easy to avoid it?  I would.
Yeah, probably right. I never had an used within needing warranties. Asus I just worry about as never had one. However my AMD upgrade I did in 2020 is Asus TUF motherboard so why not match.
Ah, nice didn't even know that page existed. I just register and close. Ha. Thanks. I guess I'll spin a wheel to pick. Thanks everyone. Appreciate you all.
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336556
In Europe - warranty isn't tied to the owner but to the product - as long as the receipt matches the product the warranty is valid.
If a PSU has 5 years warranty, you sell it after 2 and give the buyer the receipt, the second owner sells it after 2 years and gives the buyer the receipt, and the PSU dies after 4.5 years the last owner does the RMA and it's all good.
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336638
Right. Same in USA. Well with EVGA anyway.
https://linustechtips.com/topic/1422718-two-gpussend-help/#findComment-15336795
