Not sure if a problem or not. Possible cpu temp issue.
Fat old guy
Highest temp was 89c on one of the cores for less than a second, most temps spent the majority of the ten minute test in the mid 60s to mid 70s. This was with built in overclock on. Score was 12422. Screenshots below. Unfortunately I accidentally deleted the screenshot of the temps, but they were high 60’s to mid 70’s the majority of the time, but a few cores occasionally hit the 80s for a very short time, and one hit 89c for a split second this was during a 10 minute multi core test. This is with an air cooler. Should I be worried?
Even a spike to 100°C is fine. As long as it doesn't stay at 100°C, everything is fine. For an air cooler, your temps are quite good
Thanks, I was concerned when 3 cores hit the low 80s for a very short while occasionally and the one that hit 89 for a second freaked me out.I’d say the average was mid to upper 70s.
My Core i7 10750H in my gaming laptop is at 95°C all the time while playing games, occasionally spiking close to or to 100°C. CPUs will last shorter when run hotter but it's like a couple days less every year and you'll upgrade your CPU for getting too old long before it goes bad.
Well laptops always run hot. This is a desktop.
Just upgraded to new desktop and ran cinebench r23. Highest temp was 89c on one of the cores for less than a second, most temps spent the majority of the ten minute test in the mid 60s to mid 70s. This was with built in overclock on. Score was 12422. Screenshots below. Unfortunately I accidentally deleted the screenshot of the temps, but they were high 60’s to mid 70’s the majority of the time, but a few cores occasionally hit the 80s for a very short time, and one hit 89c for a split second this was during a 10 minute multi core test. This is with an air cooler. Should I be worried? screens of some results added.
I recently ran cinebench on my gaming desktop. Highest temp was 89c on one of the cores for less than a second, most temps spent the majority of the ten minute test in the mid 60s to mid 70s. This was with built in overclock on. Score was 12422. Screenshots below. Unfortunately I accidentally deleted the screenshot of the temps, but they were high 60’s to mid 70’s the majority of the time, but a few cores occasionally hit the 80s for a very short time, and one hit 89c for a split second this was during a 10 minute multi core test. This is with an air cooler. Should I be worried? Screens below.
Seems fine. Why?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
i wouldn't worry about it, sounds pretty normal to me. stress tests/benchmarks tend to push farther than normal workloads anyway.
edit: why ask twice?
Cannabis induced paranoia, nothing to see here lol
He even has a 3rd topic about his temps from march 28 but it's almost the same except in a game but these temps were not at all problematic
I mean my Core i7 9700 with a cooler rated for 130W gets to 90°C regularly while installing updates. While playing games, it stays around the 70's
Threads merged.
F@H
GPD Win 2
14 minutes ago, Kilrah said:
Threads merged.
Thanks.
Absolutely true, figured as you were comparing a laptop temp to a desktop temp I better ask elsewhere.
