Budget (including currency): around 1300€
Country: Germany
Games, programs or workloads that it will be used for: Different games from AAA to indie games. Mostly want to play newer AAA games with stable fps. Maybe some streaming later.
My current build looks like this:
  • Mainboard: ASRock Z170 Gaming K4/D3
  • CPU: i5-6600k (not OC)
  • CPU cooler: Alpenföhn CPU cooler (don't know the exact model anymore)
  • GTX 1070 (Palit Super JetStream)
  • 16GB (2x8) DDR3 1600mHz
  • 256 GB SSD (mostly for OS)
  • 1TB HDD (getting kinda old and slow).
  • Monitor:
    • iiyama G-Master GE2488HS
    • LG Flatron E2240T
While gaming my CPU is at 100% most of the time. At games like Battlefield 1 I get around 40-50 fps with drops here and there.
At first I was looking at the Ryzen 7 5800X combined with an AIO like the ARCTIC Liquid Freezer II 240 or NZXT Kraken X53, for the looks mostly, but not quite sure about it now.
These are the parts that I currently would pick, after reading some recommendations here:
https://de.pcpartpicker.com/list/2gnb8r
I will also use my GTX 1070 until the GPU prices sink a little bit more.
Also, what difference is there, if I put an extra fan at the back of the Noctua NH-D15 instead of the front? Would it even fit like that in the Corsair 4000D Airflow?
Thanks for the help in advance!
https://linustechtips.com/topic/1422025-building-a-new-system/
Honestly, that looks like a solid build, congrats!
The only thing that I would point out is that I think this case only has 2 fans, so maybe consider adding one or two intakes because the hardware can get very hot.
There isn't a lot of difference in fan positioning of the Noctua NH-D15 in this config, as far as I am aware.
https://linustechtips.com/topic/1422025-building-a-new-system/#findComment-15332526
You dont need top exhaust that just blows out the intaked air before it reaches cpu or gpu cooler. 12700 is much better value than 5900X now. You could wait for 5800x3d if you want an amd system.
PCPartPicker Part List
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor  (€360.50 @ Amazon Deutschland)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (€67.95 @ Amazon Deutschland)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  (€152.50 @ Amazon Deutschland)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€126.99 @ Amazon Deutschland)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  (€221.51 @ Computeruniverse)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (€53.85 @ Computeruniverse)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€104.22 @ Amazon Deutschland)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€103.30 @ Amazon Deutschland)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (€5.56 @ Amazon Deutschland)
Total: €1201.94
Generated by PCPartPicker 2022-04-02 01:14 CEST+0200
https://linustechtips.com/topic/1422025-building-a-new-system/#findComment-15332548
I am still considering the Noctua NH-D15 combination with the Corsair Vengeance Pro RGB SL RAM. Since the Noctua NH-D15 is such a large cooler, it will cover all of the RAM in a "normal" setup, making the RGB RAM useless from an aesthetic perspective. Now I've seen the Noctua NH-U12A, which is smaller and doesn't seem to cover the RAM (which would show the RGB light of the RAM). But how does the performance of the Noctua NH-U12A compare to the NH-D15? Does it keep a Ryzen 5900X cool enough, even when overclocked later?
https://linustechtips.com/topic/1422025-building-a-new-system/#findComment-15337958
No reason to go for Noctua at least on am4. AK620 does better.
https://linustechtips.com/topic/1422025-building-a-new-system/#findComment-15337981
