Kingston DataTraveler Exodia poor write speed
3 hours ago, Chiyawa said:Hi,
I recently purchase Kingston DataTraveler Exodia, while the read speed is on par (about 103MB/s sequential read), the write speed however is quite poor (around 30MB/s sequential write). Is this normal for this drive? The capacity is 128GB. USB is MBR, using FAT32 and exFAT formatting.
I used Kingston DataTraveler 100 G3 and I get a better write speed of about 45~50MB/s average with close to 72MB/s max.
It's strange, this is the first USB mass storage device I encountered having a poor write speed.
What do you think?
Regards, Chiyawa
I'd go read some of the reviews with images. You'll see many people are unhappy with the write speeds, so I think the drive is simply not that fast.
https://www.amazon.ca/Kingston-DataTraveler-Exodia-128GB-DTX/dp/B08JD4TBM3/
