Powering a portable display
Hman1250
Hi everyone.
I have a portable monitor, an asus zenscreen that has a single usb type c port that is used to power and display to the monitor. I was wondering that if I connect a dongle (hdmi to usb c) or a cable that is HDMI to Usb C, will it be able power and display the monitor.
Thank you
Probably not. HDMI spec only lists 300 mA at 5V a requirement. USB-C can do much, much more than that.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
