LL120 Fans
Go to solution Solved by thrasher_565,
1 hour ago, Amer said:
it has to come with the node pro that's the only way to hook fans to it
https://linustechtips.com/topic/1420127-ll120-fans/
Amazon lists 3 options.
Single Pack
Triple Pack w/ Lighting Node PRO
Triple Pack w/ Lighting Node PRO + Controller
https://linustechtips.com/topic/1420127-ll120-fans/#findComment-15318996
I bought a three-pack of these without either. $95 USD. Maybe it was supposed to and wasn't included?
Edited by An0maly_76
Revised
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1420127-ll120-fans/#findComment-15319022
https://linustechtips.com/topic/1420127-ll120-fans/#findComment-15319048
