Antec NX260 or Be Quiet! Pure Base 500 window
50 minutes ago, RazrX said:Not many options, mostly chinese cases that are like a tin can, full of RGB (I´m not a fan) and without 3.5" bays. The DeepCool Matrexx 55 MESH and Lian Li Lancool 205 (non-mesh) are other options.
Antec - $64
Be Quiet - $72 (Normal price is $126)
DeepCool - $88
Lian Li - $59
Those prices are converted from Chilean peso.
The Antec case has great airflow and is pretty cheap. The problem with Antec is that they don't have much space for cables. I have an Antec case and the side panel is literally bending a little bit because the 24 pin cable on my RM650x is too thick. This Antec does look slightly better for cable management then mine so I guess it might be worth a try, but I still don't know if it's enough space.
The Deepcool one looks decent too, but it's the most expensive.
I think Be Quiet and Lian Li have too bad airflow in this case.
