Use all of them. The 3060 is low enough power that if you don't have a second PCIE cable, you can just use the pigtail that sticks off the current connector you're using.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1418801-what-cable-for-3060/#findComment-15309316
I'll have a smaller 2 pin connecter just hanging not connected to anything is that okay?
Sorry for bad quality picture idk why it's doing that
https://linustechtips.com/topic/1418801-what-cable-for-3060/#findComment-15309321
It's fine. That is designed to be 6+2 pins instead of just 8 in case you only have 6 pins on the GPU.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1418801-what-cable-for-3060/#findComment-15309325
Yes, that's perfectly fine. Those two pins are used if your graphics card has two 8 pin connectors, and they're able to be separated in case you need a 6 pin connector (like you do).
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
https://linustechtips.com/topic/1418801-what-cable-for-3060/#findComment-15309326
41 minutes ago, Joe_ said:
do I need to use all of these or will my 8-pin do fine?
complicated answer
your GPU doesnt need additional power the 6-pin provides, but it would need it to boot because most cards refuse to boot up if it detects that it's not plugged into PCIE power
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1418801-what-cable-for-3060/#findComment-15309366
