AIO installed on the front: How to point the fans?
nitynote
I am having some questions regarding my first PC I am building.
I have an AIO that I need to place in the front of the case and I need to place also the fans in front. My case is an NZXT H510 Flow.
How do I point them? I read online Intake or Exhaust but I did not quite got how should I actually point them.
My case has already 2 Fans pre installed, one on top and one on the back.
Both of them are facing the inside of the case, I think. I can see the NZXT logo. But how do I know if they are Intake or Exhaust?
I am following this video and he actually has the same setup I have:
Prep: https://youtu.be/Az-XrAtX5XY?t=2498
Installation: https://youtu.be/Az-XrAtX5XY?t=3062
The Fan positioned like that means they are Exhaust right? So I should not do it, as far I understood ...
Many many thanks for your help!
The bit with the "grille" is the exhaust part of the fan, that's where air comes out. In that video the AiO fans are set up as intakes.
open-grille.png?trim=1,1&bg-color=000&pa
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
