Second GPU not detected/ No output.
Solved by RONOTHAN##,
First things first, do you have any M.2 devices installed? That board has it configured that when the M.2_2 slot is populated or the 1st PCIe x1 slot is used the 2nd x16 slot is disabled. That board doesn't have the necessary PCIe switches to enable the slots to run in x8/x8 mode, so the second PCIe 16x slot is stuck running off the chipset. This shouldn't be an issue for performance or anything since you are just using it for the display outs, but there are some PCIe devices that do absolutely hate running off the chipset and while this is unlikely to be the issue, it's technically possible.
