Single or dual GPUs? Help
By
jparker71
in Graphics Cards
in Graphics Cards
Solved by jaslion,
Seems like a very weak and totally wrong cpu for the desired applications. As for card a rtx 4000 is fine sli is not a thing for it it is nvlink. Of the software the autodesk ones can use multiple gpu's for rendering BUT you do NOT NEED NVLINK FOR THIS.
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking13 -
apoyusiken ·
Posted in PC Gaming1 -
6
MattJames595 ·
Posted in Troubleshooting0 -
Jimkirk363 ·
Posted in Windows4
