Case fans are dim
Solved by Ralfi,
Two things you can try:
[1] Use alternate ARGB ports on the Hub, just to see if you have faulty ports. Only change one fan at a time, so you know which one you swapped.
[2] Downloading Aura Sync to see if you can control the lighting that way…
https://rog.asus.com/articles/guides/how-to-customize-your-pcs-rgb-lighting-with-aura-sync/
Featured Topics
EphraimK ·
Posted in Phones and Tablets2 -
1
Tauktes ·
Posted in Networking2 -
4
eraigames ·
Posted in Laptops and Pre-Built Systems1 -
drumn_bass ·
3
2
5
